Even with RTX 2080, everything seems blurry and just like on Rift/Vive Resolutions (unreadable and blurry) (I'm getting angry, dissapointed already...)
Pram … toys … everywhere :wink:
So the SS settings doesn’t do anything?
You’ve restarted the shit everytime when changing fov etc?
Hmm, how is the performance if you crank up the steam SS, does it get worse?
Yes and yes. 20characters
Just making sure no offense…
Everything up to date gpu drivers, Pitool . 91 not. 95, steamvr not beta…?
Did you have. 95 installed? I had (even without the pimax) uninstalled it yesterday and steamvr was a mess.
I was wondering why games ran like 45 fps, had to tune up the SS settimgs again. This with the Vive.
Tried with beta and non beta lul and also all to date.
You need to send the headset to me.
Uninstall nvidia drivers, reboot, reinstall :wink:
Disable global steam ss settings and set them for every game individually.
@Skyrimer I think reportwd nice clarity on VD in small FoV.
What settings are you using?
I typically use pitool at 1 to 1.25 & leave steam on auto res wirh per ap setting @100%. Then adjust in program settings.
When you switch Steamvr\Video to manual what does it reccommend?
@yanfeng might have some suggestions coming from i7 4790 with was it 1080 or 1080ti?
Just about everyone. :eyes:
DDR3? Possible bottle neck.
As weird as it might be your cpu could be a factor. Though your i7 4790k is stronger than my i5-6500. My upgrade to r7 2700x fixed a lot of video jaggies etc & doubled Steamvr Base res target from 16% in auto to 36% in Normal FoV at pitool 1.0 render.
imo cpu not strong enough for Vr paired with 2080 and DDR3 .
is your cpu or cpu showing higher usage than usual ?
I think it may be my glasses…i tried to look through them through the lenses and indeed seems clearer lul but i cant force it because it will scratch the lenses…arghhhh, i need the damn vr frame…
My cpu is oc to 4.4ghz…
I need a damn VR FRAME hack right now…
I have read about bottlenecks with memory below 3200 Mhz.
Does not mater much, still 1150 socket and DDR3.
i know its a good processor but Vr is very demanding.
no offense just my experience with i7 4th gen
Did you try with contact lenses ?
Feel sorry for you BTW
Lets compare like games.
I have
  • Distance (runs really good)
  • Hellblade (hungry)
  • Redout (bit hungry)
  • SublevelZero
  • WarRobotsVR (free & runs good)
  • Vox Machinae
  • BigScreen Beta (looks best in small) no inet atm
  • Vrchat (no inet)
  • SkyrimVR (No PP runs great no mods loaded)
Need to be home to list more & can’t test eith LHes & Controllers.
R7 2700x
16g ddr4 3600
1080ti zotac mini
Win10 Pro
aint trying that. too much risks. i need a 3d vr frame from pimax so i can 3d print it…
