I will preface this by saying up until today the quality of the DMAS has been great. Very loud and clear with acceptable bass. With the exception of a little high pitch whine on the right side (audible only during silence) I have been pleased.
Unlike some users, who claim tinny bassless audio , extreme noise or extremely low volume.
Then…this happened…
I was sitting at my desk, 8KX on as usual getting ready to play. Then I suddenly heard this noise coming from the speakers.
I quickly recorded the video not knowing if there would be a problem after, but just in case.
I unplug the headset and plug it back in. noise went away.
I proceeded to jump into Cyberpunk 2077. Rrady to hear that awesome music I’m accustomed to.
And my left ear is nothing but noise and static. I can barely hear the title screen music.
I feel like I now know what others have been experiencing.
It sounds like a bad connection. Did you drop or bump the headset?
I suggest removing the center screw which holds the left earphone in place and then remove the headphone. Clean the contacts (on the earphone and on the headset) with denatured alcohol and a Q-tip (swab). Even better would be something like electrical contact cleaner, if you have some on hand. (I use Sprayway Precision Contact Cleaner for similar situations.)
Before I do I will do the following troubleshooting steps in order
Try a different pair of headphones, to rule out issue with hmd.
Try plugging left speaker directly to pc to rule out speaker faultyness.
(your tip) Disconnect DMAS headphones, clean contacts and try again.
Try SMAS headphones to see if they work worse than normal.
Try hmd with dmas on different pc
Do you know if firmware can affect audio quality? I recently reflashed the 299 firmware. It failed once stuck in DFU mode due to the “Thrustmaster bug” (Pimax you should solve this , it’s still a problem).
I dual boot windows so booting into the OS without thrustmaster drivers installed I was able to finish flashing.
So I tried all of the steps above, I opened a support ticket, nothing works the DMAS sounds really bad right now. I have had to remove them in favor of the SMAS for now.
Thats crap man. The mic is on the lower right of the headset. Sometimes a feedback loop starts. I had it happen too and picked up my headset breaking the loop. It seems reasonable that it killed your speakers as a result of overload?
Yep, Make sure they send the replacement properly documented as an RMA replacement… I had that problem back when they replaced my 5K+ and had to dance to get reimbursed.
have you tried plugging in another set of headphones or speakers with 4ohm impedance? I doubt this is an issue with the DMAS and more likely your 8KX. They are asking you to send the DMAS as they are much cheaper to replace than your headset…
Good luck with it though - if it is your headset they will say your 8KX is out of warranty, this is the issue I’m having with the high pitched whine (both sides and seemingly louder than yours if you’ve just been putting up with it).
Yeah, originally I had a slight whine in the right ear, but it was only audible when there was no sound coming out. But now the left ear has a considerably louder whine and it can’t really be ignored.
using my KOSS Sporta Pro headphones sounds perfect and silent.
If it is the 8KX I will just have them replace it with the KDMAS or something and I will await the 12K trade up
