Hi All,
The reason for this post is to express my opinion with regards to the Pimax VR unit. And also as a caution to people to not make any assumptions with regards the Pimax being in any way compatible with either the Oculus or HTC Vive.
If you read the advertising and the presentation on the Pimax web site, you would be excused if you though that the Pimax had these capabilities. Also if you thought that it is a 4K capable unit you would be excused.
But, unfortunately after much time spent with my Pimax, I have concluded that neither of these are true.
First I have not found Pimax to be able of displaying any image at 4K resolution. The best resolution I have been able to get is standare HD at 60fps.
Second, it is extremely unwise to install ANY Oculus software for Pimax.
There are too many points in the Pimax firmware and software that can clash with Oculus runtime and cause problems.
Piplay is a very poor piece of software and can lose contact (PERMENANTLY it seems in my case) with Pimax if the slightest issue arises with video card drivers.
Installing the Oculus runtime, even the earlier releases, can cause these problems to occur.
I know because I fell into the trap of installing the Oculus runtime and now have a unit can cannot be used on the VERY expensive pc I purchased specially for VR.
To give credit to Pimax support, they did try reasonably hard to resolve the issue, but unfortunately were not able to get to the bottom of the problem and have now given up.
Final suggestion from Pimax support was to reinstall Windows. Not something I will do for a product like Pimax.
Let me stress, that there is nothing actually wrong with my Pimax unit (apart from the lenses) and it works fine on my old under rated pc with a GTX960 video card. This pc has not had any other VR software installed other than Piplay. However I am certain that the problems would start if I installed ANY Oculus runtime programs.
I’m hoping that the Pimax engineers will produce an update to both the Pimax firmware and Piplay software to make it a bit more professional and fix some of the current issues.
Right now the standard of the software is in my opinion at a poor beta level at most and so Pimax is not a product I would think suitable for the consumer market yet. In my opinion it requires too high a level of technical understanding to be able to avoid the pitfalls a normal non technical user would likely fall into.
And there is not User Manual or clear operating instructions for the product and software. In fact there isn’t any software supplied with the product. So right from the outset you have to be capable of finding the right software and installing it.
Without this forum you would be stuffed.
In fact, the Pimax people are relying on the people who communicate on this forum to find solutions for them and themselves and as far as I can tell, only one person can communicate in English and even then, quite poorly.
So in conclusion, The Pimax did originally work out of the box on my new pc with a Nvidia GTX1080 Strix video card, but after inatalling the Oculus runtime things went down hill and even after unstalling ALL the Oculus software it still doesn’t work on that pc.
So if you want to run SOME Oculus games (Tatooine seems to work), do it from within the Pimax Extended Mode. Keep away from the Oculus software.
SteamVR seems to work ok from within Pimax Mode, however many VR games on Steam are for the Vive and require the Vive hand controllers and don’t seem to work with the Xbox hand controller.
However there some apps the work fine. Virtual Desktop and SimpleVR Video player to name two.
I have not managed to get DCS World to work. It starts up but again, doesn’t seem to like the XBox controller.
If anyone has this working, would you please let me know what you did.
So if you have a Pimax, I hope some of this helps you steer away from getting into trouble like I managed to fall into.
Don’t expect too much from the Pimax and don’t take the advertise seriously. You’ll be disappointed.
Basically you get what you pay for. Pimax is cheap for a VR product and I have found it to work that way.
If you are not very technically capable and want a reliable VR product, go for either the Oculus Rift or the HTC Vive.
Pimax may one day be a good VR unit, (if it survives) but thay have some very serious issues to resolve before that happens.
The most serious in my opinion is that of image focus.
Currently there is no way that I have found of focusing the unit. So if your vision is not what Pimax has considered normal, you will need come up with your own solution. Probably like I did by sticking other lenses on top of the lenses in the unit. But it is a poor solution.
I have asked Pimax for some replacement lenses, but my confidence is not high that they will send them.
Cheers, Luke
