I want this headset if I can use it to project my pc screen into it
Is that possible.
Does this come with an operating system like Android to install play store apps?
I use it for rdp and movies simultaneously, splitting my single monitor into two halves for two apps.
Not sure if this is the answer your looking forâŚ
There are currently many options to use a vr headset aa your desktop
Big screen beta free
Virtual toolbox $
Virtual Desktop $ popular
Steamvr interface (a little clunky)
Cinera headset is something i opted for. It does everything except virtual immersive experience, which I needed.
If pimax 8k could do, i would get immersive experience.
I sold my Hololens as it was having ergonomics issues and technical glitches and too costly.
If pimax has any operating system like Android, it would benefit me.
I donât game, but work and watch movies on my laptop. Cinera can help as it is Android and supports rdp.
I need a solution with pimax, I want to buy it badly, if it supports my requirements.
If all you want to do is watch movies and have access to your desktop (also remotely) then why bother with VR headset like Pimax? Comparing the Pimax to Cinera is like comparing apples and oranges! Pimax over all is a VR system for running VR apps. Playing movies is secondary. BTW, I looked at Cinera and I think having a mechanical arm to hold the headset to your face is a TERRIBLE idea in my opinion.
The impression I have gotten is that for a rectangular âvirtual cinema screenâ at about 66 degrees POV (which is about the most you can see with your optimal âfocused visionâ, as opposed to your âperipheral visionâ), the Cinera is optimised for that purpose.
It is my current belief that the PIMAX 8K cannot produce a similar quality effect from a portion of its 200 degree full POV. I donât know whether the PIMAX 8K X can with its more concentrated pixel count.
I donât know what kind of specifications a PC would need to play a 4K 3D movie on both screens of a PIMAX 8K (or 8K X). If the required specifications for this application are significantly lower than the requirements for the max quality VR experience, then the headsets may appeal to those who donât have a budget for a top-spec VR-optimised PC, as well as the headset - this is something that I donât believe has yet been properly clarified.
Itâs a shame, as I am very interested in buying a PIMAX 8K or 8K X, and if it could at least match the Cinera as a device for watching 2D and 3D movies on, there would only be a need to buy a single headset. I donât yet have a PC that could handle the VR side of things, but at least I would be investing in a product that offers an immediate benefit, and a future one.
So far though, PIMAX have not been able to provide a satisfactory explanation of whether the 8K or 8K X can do this - only maintaining that these devices are optimised for an immersive VR experience, using the full 200 degrees (which is an inadequate answer in my view, that doesnât resolve my query).
Why it couldnât as most vr players for standard video/3d video put you in a virtual theater so to speak.
If you have IMax Theater then you can likely go there in the meantime & checkout StarVR which is similarly speced to the 5k model with 210 fov (not available for purchase)
Moreover, I was a Hololens user.
I used Hololens to work on 2 pcs remotely and one for movie.
I sold it because itâs having a limitation and hiccups. I could get many headsets for that Hololens price.
Well the only thing i can truly say on movie watching experience on a 200 - 210 fov is to check out reviews on Starbreezes StarVR which has 2x1440p (2xQHD) at 210 fov.
IMax Theaters have invested in StarVR; but unlike PiMax is only available to commercial purchase.
When i have more time will look into cinera but as one user mentioned an arm sounds like a bad idea which reminds me of Nintendoâs Virtualboy setup.
Yes, burden free arm is added burden, waste of money.
But, cinera is a good concept. Should have had built in head phones too.
I would buy the new version of Hololens when released.
Pimax will be good like Hololens, if all capabilities can be integrated and itâs already better than the viewing experience than Hololens.
First of all, let me correct you - the StarVR headset is intended for an immersive VR experience for âcompanion piecesâ to movies currently in theaters, not to watch the movies themselves.
âIMAX are expecting film-lovers to almost double what theyâd pay for a movie to then step into a room next door to the main theatre once the credits start crawling up the cinema screen, strap on a StarVR headset and get involved in a short 360° presentation based in the same universe as the film theyâve just sat throughâ
Secondly, I realise that the ability to watch a movie will be possible on the PIMAX 8K and 8K X (I can already do this now on my Samsung VR headset), but my question to PIMAX is whether the image quality would be better on the PIMAX or the Cinera. The PIMAX has a greater overall resolution, but to watch a movie at the optimal 66 degrees would require you to use a fraction of the PIMAX headsetâs overall screen area, and my current understanding is that the Cinera would deliver a sharper image quality in this screen area compared to the PIMAX (because it is optimised to use a greater proportion of its overall screen resolution, resulting in higher pixels per degree).
I would probably buy a PIMAX eventually, even if the cinema experience is better on the Cinera, as I will eventually want to enjoy more VR content, but for now my priority is personal cinema - if PIMAX can deliver the best current cinema experience (or equal to Cinera) AND do the VR as well, then I might as well buy one now.
