Boarderland 2 VR for pc
so we need new controllers for lazy devs ,can you tell me if there is any way to use touch controllers with vive base stations or are we really getting screwed and how quietly
There is no such way, unfortunately.
But with sticks you can play pretty well :wink:
This is the same as RoboRecall, Arktika.1, etc.
not at that price…lol
Honestly I dont care how well it work on oculus I’m not forking over the money for a full priced game to a developer that cant even be bothered to test their product on more than one headset. Remember, when this released it was advertised as being compatible with ALL headsets. Its been a long time since I’ve last seen a developer botch a release this badly.
so after watching this, they may as well have made this rift exclusive because it seems thats the only headset they actuall tested with.
Theres a rumor going around theirs a patch coming but i cant see or make sense of this
https://steamdb.info/app/991260/depots/
Its quite remarkable that exclusive titles even are allowed to exists on Steam. And then punishing their own userbase with a 50 dollar price tag…
It seems corrected for Vive :ok_hand:
Working on pimax now?
And I have not tested it yet, because did not buy this game :wink:
I’ll wait for the patched version on the torrent, I’ll try and then, if everything is fine, maybe I’ll buy it.
Edit. removed the torrent link -Trevor
Yes! Not the best in the world, especially if you’re using the Knuckles, but I’m IN Pandora! Weee!
PP needs to be on.
let us know if its fixed.
Yes, I will check as soon as it appears.
How’s performance with PP on?
Works quite good with PiTool 1.0 and Normal FOV, 72hz.
I always enable PP in all games, and just fine-tune SS for it.
This eliminates the need for constant switching, more comfortable :+1:
(The per eye resolution is usually around 2400x2100)
Now it will be interesting to see how it works without Revive.
I would like to know if you have the same experience with PP as I have stated in my thread ‘Compatible with parallel projections is broken’.
In general, I did not notice problems with PP. Everything works as it did before. (PiTool latest version .180)
I have not encountered such a problem as yours.
Although, I must note that in BL2 VR the inscription with the task is rather small and inconvenient for reading.
But in general - everything is normal, the SteamVR panel is very well read.
How wide is the mini-map and can you see the whole health and shield bars?
Yes, the minimap looks strange, it is very narrow and of little use.
And below, where are the HP strips and so on, everything is perfectly readable.
Summary
can u provide a link to that?
