This setup is for advanced or semi advance vr simmers which playing a lot in AC AND WANT THE BEST POSSIBLE DISTANCE SHARPNESS AND MUNCH BETTER COLORS ,SATURATION AND MAINTAIN SOLID 90 FPS .Setup in my video is prepared for at least gtx 1080 or 1080 ti and modern i7 processor.
This game in Pimax is surprisingly dark and colors are bleach and faded.
So please download custom launcher and content management app for Assetto Corsa. Content Mananger is still in development, new features are added regularly. Please consider father updates.
When we have mods instaled we are not runnig this game from steam anymore but form DESKTOP shortcut.
Instead of in game PP filters recommending shaders-patch for Content Manger it’s so munch better than in game Postprocesing filters, and almost don’t hurt your performance
Personally I don’t like in games PP becosue non of them give good colors , saturation , filters are not VR friendly and based my experience they are taking sometimes 20~30 fps when you run game with high resolutions like 4000x3000 pixels per eye . And we need this high res for the best possible sharpness and low SDE
Links to 2 mods:
Contenet Manager https://acstuff.ru/app/
and Shaders Patch
and go to my YT setup guide:
This game shine even better thanks to this MODs . There is a lot of gfx settings options to play ,
sky is the limit guys Enjoy
Wow ! Impressive clarity and sharpness…I play AC a lot on my racing rig and still have to get to a satisfactory graphic quality settings using the Od+
It would be interesting to see how this launcher works with an Od+ and find suitable settings for it.
@Yata_PL Thanks for the guide. I have downloaded the full version of CM, when I click on the CM patch tab, it says custom shader patch not installed. What do I do with it? Sorry I’m new to this Content Manager thingy.
I did went to the second link, click on the 0.1.24, and then click install, open up CM, nothing happen. When I attempt to close CM, it says something is being install but I don’t see anything being download.
Edit: Never mind, I figured it out
@Yata_PL finally got it working! now my main issue is supersampling. I set OpenVR supersampling ingame to something else than 1.0, save, restart, not changing still on 1.0.
Am I the only one that can not set anything else than 1.0?
edit: Jesus, who needs ingame SS. like you showed: pitool 1.25, 70% Steam SS, -1 LOD bias and that thing is clean and still runs at 90fps, unbelievable!!! thanks man!
That is madness. Much better resolution, colors, contrast and also the black value.
In addition, the native resolution can be adjusted.
Wonderful. Such settings should also be possible in the PiTool. Thank you!
I still dont know how to install the shaders patch. I click on install using CM and CM opens but it shows me :
“Custom shaders patch is not installed”.
