Can anyone help with some decent 5k+ Settings for ACC?
I have a 9900KS, 2080Ti, 32gb@4000, running off an m.2 nvme ssd.
If i push too far it seems i get a menu/game flickering. I hate using motion smoothing unless it’s needed and it seems like it might be needed here
Can anyone help share their in-game, pitool, and steamVR settings? Also, if theres anything i should change in the Nvidia Control Panel as well?
@Yata_PL - i found your old menuSettings.json file from a few months ago, but when i overwrite the settings and save it, start the game, it starts with Default settings and changes everything in the file - do you know why?
If You don’t update the maxRecommendedResolution setting in SteamVR it might “work” but You’re not getting 400% * 140% * “native” resolution on 90Hz, that’s for sure…
I posted my settings somewhere here a couple days ago. Most important for me was the AA and the Trees. Pi tool is at 1.25 and steam at 100% for my 8k+.
Using high/epic KTAA gives more sharpness in the distances and reduced flimmering effect between the eyes. Also setting the trees to high stops the LOD from placing different trees per eye and makes the image more stable. With that I can be near 45-50 fps
Ye i noticed if i push the settings, i start seeing flickering in the middle of my eyes.
and yes i noticed that weird effect with the trees too.
Are you using PiTool SMart Smoothing or SteamVR’s Motion Smoothing?
Both not, I dislike the “stuttering” effect.
I also saw I did the FPS with 120% in steam.
If you hit epic with KTAA and the foliage those wired effect are almost gone.
I just used @MReis settings and i got avg 80fps and looks decent so im sticking to his. There’s a few things i can tweak but if i push too much i get the flickering in the menus and if i push too far, it starts happening in the game as well, but i found a decent balance im going to stick with. I wasnt using KTAA which i think was one of the reasons of the issue and some of the settings he has on Low when i had much higher.
Your 400% SS Value makes no sense to be quite honest. No game ever needs that much.
I tried a grid of 20 AI on 2 tracks with light rain and stayed 60-80fps. Average being 80+ fps but some dips where theres stands and alot of cars to 60fps.
Gpu wasnt even 100%. It was around 78-85%.
I have to try playing with catalyst also and i think i have some room to push on some settings before it starts flickering again
Your settings really did it for me i think i just gotta tweak more.
Im on a 9900KS@5.0ghz, 2080Ti @2.1, 32gb @4000mhz, and samsung 970 pro
All the LOD Stuff e.g. Foliage on epic causes it for me to flicker less (the trees being rendered different on the left and right eye) and costs about each - 2 FPS.
Also the Texture can be put up on high/epic
in average pushing shadow, foliage, AA on epic costs like 6 FPS
Might also want want to check if the sharpening filter does something good to you.
