Thanks for the reply.
I am assuming your statements are based on some experience.
“VR and AMD has always been inferior to and Nvidia.”
I am not clear how “has always been” applies to the two new generation graphic cards. (though we do know something about RTX).
Well, I could not buy the 3080 or 3090 for love nor money, worked for months to get the 6900xt. (and I am probably an AMD fan boy).
foveated rendering: while it may not be implemented on pimax and AMD YET. It is coming.
Fixed Foveated Rendering in new AMD 6000
“…never in combination with Pimax HMDs.” A bit of a strong statement. But, then I did ask! And it is a clear opinion. So thanks for that.
Chat with Pimax.
I spoke (online – in Chinese) with Pimax Official Shop (Chinese online store) yesterday. A follow up from my chat last week.
“A卡兼容不好目前问题在于哪里,未知。所以只能建议等等换N卡在选择入手”
Translation:
“A [AMD] card compatibility is not good at present the problem is where, unknown. So can only suggest and so on to change [to] the N[Nvidia] card in the choice to start”
Can I quote you on that.
“我的话没有任何讨论性的,我这边只是不建议使用A卡因为可能导致无法使用的。”
Translation:
“My words are not discussative, my side just does not recommend the use of A card because it may lead to unusable.”
“建议您等待一张30显卡,在选择考虑入手VR”
Translation:
“It is recommended that you wait for a 30 graphics card before choosing to consider starting VR”
“我们设备一直以来都是不兼容A卡的,主要兼容N卡为主的 。问题具体在哪里我们也是不清楚的”
Translation:
“Our equipment has been incompatible with A-card [AMD graphic cards], mainly compatible with N-card-based [Nvidia]. It is not clear exactly where the problem lies.”
“刚才咨询了一下,技术人员。我们建议用n卡,我们的工程师测试过a卡兼容性不是很好,有时会连接失败。所以我们也是无法保证百分百可以”
Translation:
“Just consulted, technician. We recommend using an n-card [Nvidia], and our engineers have tested that a-card [AMD] compatibility is not very good and sometimes the connection fails. So we can’t guarantee 100%.”
How will I know you have updated your drivers?
“可以百度搜索: Pimax小派官网 在官网查看”
Interpretation: “look on the website”
Pimax chat ends (all very polite).
This leaves me with the same questions I had yesterday.
“How does the 6900xt perform?
Would you recommended the 8kx or the 5x supper?”
With the expectation that, at this point, the 6900xt will not perform as good as is will, after driver updates.
