More control over contrast/brightness. I think something between 0 and 1 contrast is a sweetspot where we won’t see any color “crush.” Maybe increments 0, 0.5, 1, 1.5, 2, etc, or even better, 0.25, 0.5, 0.75, 1, 1.25, 1.5, 2, etc.
Short push of the power button brings up the SteamVR menu, and a mouse dot in the middle of the view can be used to access desktop/settings/etc without using a controller(use head as a mouse pointer). The Index has this feature and I really miss it while using a Pimax headset. When racing and desiring to check the time, or a steam message, or change a setting, I currently have to find a controller, turn it on (and waste battery), and navigate with it, where with an Index I could just press the power button and then use my head as a mouse and press the power button again to “click.” The way to turn off the SteamVR settings is to point the “mouse” pointer off the settings/desktop screen and short click the power button again.
if i’m already in steamvr is there a way to get back to the pimax experience menu? i’ve always wanted a pitool menu overlay in steamvr that works the same as ovr advanced settings or revive
Agreed. Incredibly useful to have a power button tap bring up the steamVR menu, and also having that same button press able to select items you are gazing at.
Really hope this can be implemented into pitool. Having to turn on controllers just to do simple navigation in steamVR menus is a big con for user friendliness in my opinion!
Yes, that’s the idea with cloud enabled profiles, but to begin with You’ll have to set up the profile for each game once (and it will switch profiles upon start of a game)…
Enable lower refresh rates for 8K-X like 64Hz: great for older flight sims like DCS or X-Plane
Backlight controls for 8K-X (potential per screen, my left screen seems slightly brighter)
Outside of PiTool: provide easy to understand, step-by-step instructions that can be published to game developers explaining how to update their games so that they no longer need parallel reprojection.
Any idea what the current lowest refresh is for production 8kX units at the moment? My pre-production goes down to 60Hz, and that works really well for flight sim and such.
