8K X SMAS hinges need improvement· - can we DIY fix it?
I switched left to right but it’s too low now. I hope they send me out the right hinges soon, or I may try and buy some 3d printed ones.
Please do. My aftermarket hinges do much more than any of the hinges Pimax is currently offering. :wink:
Are you sharing your STL ?
I think I remember you have a design not requiring any printing supports ?
There are a few ppl that have made new hinges.
@BNP and @MikeJeffries were working on some when this issue was first identified in the wild.
Yes, I am, and my design indeed does not require supports. I plan on making an announcement once it is listed publicly for sale, which will be any day now.
Thank you. Finally I’m making my own design starting from Pavel Ruban’s work.
If you guys need some hinges design I can make some and share them for free.
I am printing those right now
hingesoculuspimax
To make this fit on a Pimax hmd
I, for one, would greatly appreciate that, @Ludiks. Thanks in advance!
Ludiks, Thanks for posting this strap in the discord too. I decided to buy one for my Quest 2 actually. I returned the Elite headstrap because it felt so cheap for $50… This one looks way better and its cheaper.
I just notice I missed lots of messages here, how about the Teigue design? Is it not good?
@MikeJeffries Did you order the Quest 2 model? Because this one was for Q1.
This is how it looks on my 8k, works very good :
That is sweet and likely a great option for Those whom want to use there own high quality :headphones:.
Good call! I just put in a cancel request and ordered the correct one for a Quest 2.
@Ludiks @MikeJeffries
Could you guys repost a link to the headstrap you are talking about? I cannot seem to find anywhere, yet it seems to be a common knowledge somehow :thinking:.
Folks, please don’t miss out on my hinges which allow the MAS to lower to any desired angle. You can print them yourself, or order them from us.
https://community.openmr.ai/t/announcement-aftermarket-8kx-hinge-assortment-available-get-yours-here/33142/4
@Ludiks Tiegue’s design works fine. My version makes them easier to 3D print, adds a metal reinforcing screw, and is available at a variety of angles for those who do want to use the end stop limiters. I am using a 161deg pair of these hinges myself right now.
Hello Luds,
Great work pal!
Thank you so much for sharing this with the community!
Sincerely.
@mirage335
Oh yes, great, actually there was too much message and I think I got lost here. Good one !
@PimaxQuorra Thank you.
