Thank you! It has been difficult to pick a headset without trying it out first-hand (as so many know). I really prefer the benefits of the 8K, but fundamentally, all that matters to me is which is better for playing Elite. I guess I’ll keep my current 5K+ selection.
The blacks should be better soon, when we get a backlight brightness control. Of course, this will be at the cost of a dimmer overall image. I’ll probably dim it, at least a little.
@Ludiks we used pitool 0.91 (newest) during the event
Edit: Okay your post made me look into things more and I just learned that parallel projection is only a problem with the blurriness in large FOV!! So they fixed large with with parallel projection off but not when it’s on.
If I keep pitool in normal fov skyrim looks just like it does when pp off, it was the large fov with pp causing blur (parallel projection bug)
tldr; large fov basically broken with parallel projection on from the bad blur.
We are several here to have reported a loss of clarity for weeks in wider fov, I did about 2 month ago.
I dont even talk about the last even but all of them actually.
It’s a shame because you were right about parallel projection. They should fix it (large fov is blurry still) I am just happy they fixed it for when parallel projection is off now.
I think maybe the issue your english was hard to understand there (sorry!) I can sort of tell it’s not your native language, and maybe it did not translate well to Chinese? (if they use google translate)
@Pimax-Support Pimax please fix the large fov blur with parallel projection on.**
With parallel projection on not fixed on large fov! bluurry when I check
But yes correct it was fixed with parallel projection off ( if that’s what you mean) I just got the headsets actually and only have experience with .91 pitool.
Just want to be clear here. lol
Like I Said seriously unlike sharpness and other aberrations, color perception can vary greatly from a individual to another so in case of a “dispute” like this the only way to be sure for you is to tried it. So you have to take a leap of faith
Ok I got it, its only when you are moving your head very quick (has he said).
But…thats tests, you dont do that in games 99% of time.
Its just like hitting a wall with a car for testing and result is “this car doesnt hold againt a wall, dont buy it”.
And Sebastian was reporting it to be present most of time when moving head normally, I never saw it moving head like that in one of his videos but of course I didnt see them all.
Yes best to get fellow ED players input. to me the 8k is plenty clear; the discrepancy to me seems to be more individual preference than anything else.
I have Redout, Hellblade & Alien Isolation. All prefer decent on either headset with appropiate settings.
Hellblade & redout require tweaking. But have gotten Hellblade fairly stable around 70+ I believe (see my first review).
Redout Performs decently but hard to get high fps. Think if mem serves around 70.
Performance wise both perform well; in games where possible you will hit the 80 or 90 respective headset. As @SweViver has said tge quality/performance gap is pretty close.
I would say @Enopho would be a great reference on getting optimised settings for an 8k user to tweak settings as he runs ED on the p4k(uses scaler from 1440p to 2160p).
yeah that’s the problem. I think it is close, because with the 5k+ i had a"more of the same" impression with the screendoor, washed out colors, contrast exept for the field of view. in the beginning you think oke its just colors but after half year with my lenovo i have had it with that.
On Lenovo a good small SDE, you can survive with this.
The VivePro / OG Odyssey SDE is worse than Lenovo.
Now, in order (about the difference SDE Lenovo and Odyssey).
in Lenovo, the pixel itself is smaller by 12%, in spite of the higher resolution of the Odyssey (ie, pixel density is higher for Lenovo)
The screens of both helmets are different in size: Odyssey 3.5 ‘’ 1440x1600 vs Lenovo 2.89 ‘’ 1440x1440. Based on this, the density is higher on Lenovo.
So the SDE effect is definitely less pronounced on Lenovo (and similar models) than on Odyssey / VivePro.
But since lenovo is not quite a standard RGB layout, the pixels are still quite visible on bright, even surfaces due to double spans, when two pixels form one lane. But this is not so significant, because SDE is still smaller, even if it can be noticed.
Not so long ago made a small comparison through the lens of Lenovo vs Odyssey.
For me, there will be a huge step back, if SDE is similar to VivePro or Odyssey. I want it to be at least a little better than Lenovo Explorer. Therefore, I definitely choose 8K
