Is your power adapter making noise?
No, I don’t think so. Will check tomorrow to be sure.
I am overall pleased with the image … only thing is the horizontal lines.
@Doman.Chen can you maybe send me the command line tool with instructions to fix horizontal lines? (Maybe via pm?)
I am busy this week so won’t have time for remote access session yet.
Please PM me when you are available,thanks.
Could you provide more technical information about this issue and this setting?
Sorry,I have no idea with it,what i know is how to set flick values.anyway,I will ask our engineer about this and reply to you.
I have tried setting the flick values and found 8 the best.
It seems to be most visible on solid bright blue backgrounds. (eg. on the SteamVR buttons at a certain distance).
Setting at 8 they are still there but are a lot fainter and show up a lot less in normal usage
It still bothers me sometimes but at least it at 8 it is a lot better than other values.
Hopefully Pimax can tweak it further … maybe allow more fine-grained setting.
What was the first value?
Update: I have found an even better setting:
L-8 R-9 (different value for left and right).
This made the lines even fainter and is the best setting I’ve found. (A lot better than L-7, R-7 or L-9 R-9)
I think it started at out L-9 R-9.
@Doman.Chen I have the same problem. I have opend a support ticket SUPEN-3283 and they want to send me a replacement headset. But if it’s possible to solve with a software trick please also give me the command line tool so that I can fix it because then it should not be necessary to do a replacement.
Which headset did you recceive? Backer or pre order?
Please PM me with your email,I will send you something by email.
8k Headset. Backer 5695. @Doman.Chen. I will reply to you with my email address
Awesome thanks!
@anon74848233 please add to earlybackers.
Now it’s much better for me with the tool. Original starting is La/Ra …
Switch both together was not really the best way
Interesting is that it switch from left to right panel when I have Lb/Ra (at first it was only the left panel when I reduced both)… So now my best config is Le/R9 where I can still see it on blue sky but as I started with La/Ra I had it on every background color
I renew my invitation to provide proper information for these settings. We didn’t have to deal with these cryptic messages without knowing what we’re doing.
Indeed @Doman.Chen please release these console codes for adjustments otherwise you may end up sending an exhausting amount of emails on it.
Please try the latest pitool and firmware,reset flick again.
Hi, I just have received my 8k headset and I have the same issue, could you please help me @Doman.Chen (installed the last pitool beta in order to try last features) ?
Please PM me with your email,thanks.
