Ok , so I upgraded my PiTool to the latest version this time. And 144hz is still cross-eyed. There’s definetly something wrong with the profile. All other refresh rates (120,90,72) look fine.
EDIT
If i drop the IPD Offset to -10 or -9 the cross-eye is gone
weird.
On 72-120 hz i can leave the IPD Offset slider in Pitool at 0 and the physical slider all the way to the right. (My actual ipd is approx 70mm)
but at 144hz i need to drop it to -10 and when i touch the physical dial it says my ipd is 64 (max dial to the right)
People keep making a stink about the cross eyed thing but it’s an easy adjustment to ipd offset. I am impressed with this update, except for the catalyst which seems to only produce visual glitches amidst the performance boost. It does show promise though.
No, you don’t understand.
I tested different pitools and in the end the 197 is the one that gives me the highest fov with the 120htz.
with firmware 255
I have had several versions of the 5k+ in my possession since February 2019.
I have a model 204 at the moment
I’ve been testing different pitool and firmware versions since 197.
without tampering with anything.
I tested the 144hz on my Pimax 5K+ ser 203 and it worked for steamVR home, the FoV is great. The strange thing is that resolution is still not the same than other modes, the available resolution is either smaller or bigger than the “small” on 72 Hz.
But unfortunatelly, it is not usable for DCS and IL2 GB. There is no possiblity to have 144 Hz for these game, and currently SS will need 72 Hz. That’s not possible in all cases for IL2 GB (that do not like SS anyway, it introduce a lot of glitches), and abolutely out of scope for DCS, which seems capped at 50 fps max for VR.
So I wonder if it should be possible to have other Smart Smoothing factors than /2. As I understood, Smart Smoothing is “interpolating” images between computed images, that is one image on 2 is interpolated. Could it be possible to have 1 images on 4 computed and the 3 others interpolated ? or maybe 2 on 3 for 120 Hz ?
So we could have 144Hz fluidity with frame rates compatible with some “heavy” games. I do not know if it make sense…
