5k+ 202 series can try 110hz now. beta testing firmware to be released after CES
How many backers have the 202 units? Do we have a general idea?
Good qn…
https://community.openmr.ai/t/pitool-supports-now-120hz-for-5k-202-series-but-its-unusable-its-so-dark-you-think-the-screens-are-turned-off/25344
1.0.1.253 is not yet the PiTool including FW upgrade for 202 Series
So after CES has become after Chinese New Year, (at least) 2 more weeks to go…
@Heliosurge please keep us posted here :wink:
The alpha 254 in Release Notes also has a special 202 FW only.
I’m on Serial # 2036… and am not seeing an option for 110hz. Can anyone chime in on if there’s anything special to getting it to show?
@MagiJedi :thinking::thinking::thinking:
WARNING FIRMWARE ONLY FOR 5K+ SERIAL 2026
  • Don`t update this firmware to other headset models!!!
I only did pi tools.
110hz is 5k+ serial 202. 203 & 204 have 120hz
Ah thanks for clarifying. I originally thought it was just an extra option.
There are only three 5K +
Hmmm… Pimax 8K+ is 206
Wondering what is 205 ???
:kissing_heart:
Don’t know until now only saw the 3 mentioned until your post
I am a winner with 2026XXX yay :slight_smile:
Some Feedback:
So today i’ve updated my preorder 2026… 5k+ to 2.1.255.262 and Installed PiTool 1.0.1.254_alpha
After HMD and Service restart i directly could set 110Hz mode.
Fired up BeatSaber and the RTX2080ti had no issues to constantly keep 110fps on 100% steam render setting + 1.0 in PiTool
I did not quite see the difference to 90hz but all in all it felt way more fluid. I’m not an expert @beat saber but i pretty easily increased my hit ratings from B/C to A.
After a little over 1hour continuous play of BeatSaber the HMD crashed though. It got pretty hot from outside and seemed to restart. I will let it cool down and try some more games tomorrow.
PS: HMD still does not save the front LED color set in new PiTool, the set color stays in PiTool but when restarting HMD the headset always starts with default blue and you have to change it to another color and back to your wanted color again in PiTool
The special firmware is made for 202 only as release notes states. Be careful as Notes did say not to use on other headsets Serials.
I updated my 2026 using the manual flash procedure in SweViver’s video from ages ago haha
It’s subtle but I notice the difference. Just threw on Elite and even only hitting 50fps in stations (due to me pushing quality) I can tell. And Arizona Sunshine is also more fluid now. Not a fan of Beat Saber but will try a high fps game
Nice one Pimax. I’m happy you pushed to give our super-early models 110Hz
Cheers
My headset has been crashing constantly since I installed the new pitool. I don’t know if it is pitool or something else but I’m only running 90hz and on the same firmware I’ve been on the whole time.
I haven’t seen other posts about crashing so I haven’t suspected pitool but the only way to fix it is to restart the pitool service.
Anyone compared the FOVs yet? I just play beat saber at the moment where it is not as obvious but 110hz large FOV seems just as large as 90hz to me.
Oh wow. That could be possible and perhaps an advantage of 202. By running at a slightly lower refresh rate a larger FOV will be possible. If so I would really like that as an option for other headsets. I would much rather the same FOV as 90hz with 110hz than having the smaller 120hz FOV.
Meant 2026… in my previous post of course :wink:
Btw. You can flash it very easy with the DFU.exe tool in PiTool directory, no need to do the manual hazzle to bring the headset into DFU Mode, the tool will do automatically…
So tried it again today, again crashed after ~40minutes, will try maybe older PiTool with 90hz mode then leaving the FW of the HMD @2.1.255.262
