With good support from our valued customers and the community. Pimax team will always try our best to extend the potential of VR if there has.
We’re planning to release a new firmware for 5K+ users testing
That’s probably what the normal mode 120hz will look like , I like the small 120hz mode personally because I can crank up the supersampling for quite a good image
Didn’t we already have 120hz at normal fov though? I mean I was def playing the forest vr at 120fps at normal fov. Would you mean by any chance large fov? As always, thank you for your commitment to bring the bleeding edge to us!
What do you guys think to adding postprocessing injection support to Pitool? It would be a killer feature that would really seperate you from the pack. Most current post processing injectors don’t work in VR direct display mode.
In 90hz mode Wide and Normal for me have rounded sides like a racing helmet. I like this, it feels natural and immersive.
In 90hz mode small and in 120hz Normal and small the framing has clipped edges. It has round corners with flat sides. I really dislike this and I wish every mode had similar framing to the 90hz Wide and Normal or at least 120hz Normal was similar with rounded sides.
Is yours different to this?
I also saw a 202 owner suggest the 110hz mode for him was the same as 90hz Normal. If so I am jealous. I would rather have 110hz looking identical to 90hz Normal than have a smaller and clipped 120hz.
For my 1070, small fov is the best fov which I can boot super sampling and get the best quality of graphic and less distortion.
But I test beat saber last night ,it look small fov not much different from normal fov while I can see more different by oculus dream deck.
Still not try normal fov with higher gpu. But 120hz fov look like and egg shape and if it can’t make the fov look like normal fov, at least I need it to look like small fov.
I use both of this, I think firmware shoud be 248, but I try to use this firmware although it specific to use with other serial number (I have 203 serial)
Are you sure you are using FW262? That is not meant to work with 203?
Can you just confirm to be sure? Open Pitool with the headset powered on and navigate to Settings > HMD. It will tell you at the top what Firmware you are running.
