thx.
For some reason I don’t understand I could make oculus setup without loosing pimax connection.
But -maybe is it a silly question- is there a way to get the oculus home interface? With revive I can access oculus apps but what I want to do is accessing oculus home interface with Pimax. Is there a way to do this?
Salut les amis “Pimaxiens” lol
Encore un français sous le charme de ce casque, qui éssai de comprendre ces astuces et son bon fonctionnement également :Miam:
traduction :
Hi friends “Pimaxiens” lol
Another French under the charm of this google, which tried to understand these tricks and its smooth operation also: Miam:
Hi i have the same problem i have an lenovo laptop i3 processor 8GB ram 2GB AMD graphics
my headset doest not support direct/Pimax mode i even tried disabling the integrated intel graphics but no luck it dosent ebn detect any display if i do so i went and there is no option in the bios to disable it i did it from the manage->Device Manager …yet after all that it did not work
Please follow the tutorial from beginning to end! Because everything is not played in the bios for some motherboard or integrated graphics intel, launches a service at the start of your PC.
Read the procedure correctly from A to Z. After I am not a developer but a simple user that is broken the head to finally find the solution, then this one can, may be work for you!
Put this service “Intel ® HD Graphics Control Panel Service”
Stop and deactivate
And check as if in the bios you are in graphical parameter “PEG” and not “IGD”
Personally, I went back on windows 7 64 bit pro, I remade all my installation and disabled my internal graphics, and like magic with windows 7 no problem! I think that with windows 10 there are too many worries!
