Warning: Tutorial try on PC Fixed and not PC laptop !!!
And version Piplay 1.74 !!!
My configuration:
Windows 10 pro 64 bit
GTX 970
MSI motherboard
I5 3.70 Ghz Overclock
Pimax 4K ( ^^ )
I am French, so I hope for you this will be the same !!!
Thank you for your understanding!
Finally this crazy story for many of us is going to end, Alllloooo houston … engineer friends, you should take into consideration this Tuto to avoid the thousands of people who have lost their head against the wall ^^
First of all :
Ensure you have connected your display to another hdmi or DVI port on your GTX 970 graphics card
Plugged your PIMAX “USB + HDMI”
OK …
From the office:
I noticed in the manager of the peripherals that my internal graphics card “intel” reinstalled each time, even when I uninstalled it in the BIOS, or that I disconnected it in the manager, it is crazy;
So I thought there is a service that reinstalls it in the background!
BINGO simply, since the time I look for this stupidity!
Because every time I turn on my computer, the graphics card inter inte intel prennais the top and therefore also on the pimax despite all my attempts to deactivate and uninstall!
Tutorial:
So I press the key “windows + R”
I write: " services.msc " then " enter "
And I search this damn service that creates this problem!
