Wrong IPD and out of focus
I just bought the pimax and I’m trying to play IL2 Sturmovik.
I measured my IPD and it’s 65mm.
If I set that in IPD configuration I get 2 images completely separated. But Ok, I’ve used chinese software before, so I set it in the software to about 54 and it seems right.
The problem is, no matter what IPD I set, I can’t focus in the game, I see double all the time.
I can get a single image if I really force my eyes, but that makes it unplayable as I would go blind in 3 minutes.
@Pimax-Support @Doman.Chen @bacon
Can you post your system specs, piplay version & firmware & first 3 serial number of headset.
Does the pimax logo give double vision? Have you tried other titles? And lastly do you have vision issues that require glasses?
Hi, complement to @Heliosurge, may I know your eyesight situation, wear glasses or not and the label of serial number on the headset, thanks.
