Hey dear community. What resolution do I have to set steam vr to in order to achieve the best result, for example with ProjectCars2? I just set it to 500% as a test but the graphics were much worse than 142%. At 142% I have a resolution of 1920 x 2368 per eye.
Might be an idea to share specs. I presume your running a p4k?
Pimax 4K
rtx 3070
i7-6700 3.4 GHz
Pimax 4K
AMD Ryzen 7 3700X
GTX 1070 TI
and sooon i hope NOLOVR for headtracking and controlleur
It’s been awhile since used the old p4k.
What I would suggest is keep steam’s SS at the lower setting and try using pi render at a higher value.
do u still have it ?
Somewhere. Didn’t want to part with it. Plus the headphones were awesome! Likely will mod them to checkout on one of the p2 models.
It is suggested to select the appropriate display resolution according to the actual usage scenarios.
Apple
