Where is this PimaxXR found?
I read mentions on the net about PimaxXR giving a slight increase in FPS over SteamVR and OpenXR?
I’m wondering the following,
What is it?
Where is it downloaded?
How do you run and disable/remove StramVR (I use) ?
I’d like to use it and see if I get any increases in performance.
Do you need OpenXR to run it? How is iRacing opened with PimaxXR/OpenXR ?
The dev of this great software @mbucchia has created a very good manual/wiki at the link that should answer your questions.
Try 0.3.4 for now. Should likely see perf increase ~5 to 10 in my testing.
I notice just now that mbucchia accepts sponsors on his GitHub page, by the way…
I may not today use XRToolkit, and his other IMHO absolutely vital efforts, but sooner or later I’m bound to… could be worth chipping in half a bit… :7
