I understand BE is the business edition but aren’t the specs worse? With the BE it’s 85±3Hz?
so… 82-88Hz?
whereas the 5K is just 90 Hz
I don’t really understand why it costs more, if someone could explain that would be great thanks
so… 82-88Hz?
The 5k BE is an Oled where as the 5k+ is lcd.
Oled Panels cost more but give benefits of true blacks & whites. However these panels often suffer more SDE due to less sub pixels (2 vs 3).
BE models I believe also have a Business related warrenty due to more potenial abuse.
Ahhh I see, so would I be okay just buying the 5k plus?
as in, I would not be missing out on anything
yes, 5k+ is completely ok
As Industria said the 5k+ would be a good choice. The prime difference is the display panel. Usage otherwise would be the same.
I haven’t yet received my headset so based on second hand information I am led to believe the 5k+ is a great choice. However if you play a lot, and I mean a lot of elite dangerous then like me you might consider the extra cost for oled panel acceptable due to much better blacks.
