but still thanks for the answers and the sjefdeklerk´s flasher is much more better.
one qustion. should i use the render setting in pimaxes settings at highest or crank settings up from somewhere elswhere ?
i have titan x (pascal)
Lol sorry tbh; i think we all presumed you tried tge headset on.
We have all i am sure missed obvious things.
I for one didn’t know how the defogger/demister worked & in the early days i got strange texture pops of white. (now just a couple of flashes & done)
I simply thought due to my rig being weaker than reccommended figured it crashed & rebooted my computer. Lol
One user has mentioned only use one of render/super sampling
So if you bump piplay render up leave steam’s supersampling @ default 1.0 or vice versa.
I would reccommend start at 1.5 - 2.0 & bump up til quality vs performance meets your desired needs.
okey steam has it´s own. thanks
by the way do you have any tip on the fact steam vr stopped working. so i removed it to install it again,
but now i don´t find it anywhere
Weird steamvr should show uo un your library but more importantly there should be a VR button in your steam titlebar & piplay’s steamvr button should launch it
there was but it was not working so i uninstalled it. now there is no “steamVR” to be found from steam…
It won’t install? Try search steam for it & see if it needs 2b install
ok finally. it can only be found by going to libraty /tools. …allthough i thought i had tried that out before but who knows
Awesome. In the store’s search bar it should have shown under “steamvr”
Sorry for laughing. Haaaaaaaaaa!
Yep, there’s a sensor in the HMD that detects your head (When it works).
Also. It should be on the very top right of the Steam screen. It shows VR.
Click on that and SteamVR will open.
Do you mean my head ;D …
yes if it´s installed. atleas from my steam you could not find it else you go to tools and make a search SteamVR
the point of the image was that Heliosurge said to seach with the store search
Yes it comes up one word SteamVR lol
