What do short-sighted
I have myopia -2.5, it is technically possible to see in Pimax without glasses? they interfere with and distort the picture. Perhaps you can change the distance between the screen and the lens? not planned the production of lenses for short-sighted? this would increase the prestige and revenue of the campaign!
Yes, it should since it support adjustment for up to 500-degree myopia which is -5.0 dioptres
and how to do it?..
I believe you adjust it within the software, which then moves the lenses
