War Thunder-Aircraft don't render until really close see
In War Thunder, aircraft appear as dots until they are really close (aprox 200 metres), then they pop into view. On my HTC Vive, this wasn’t an issue, but it’s something that always been an problem with my Pimax 8k. I post now because the issue seems to be getting worse for me. Does anyone else experience this? Has someone got a fix?
PC specs. Core i5 9600k, 4.8ghz OC. Ram 16GB@3200mhz. SSD. RTX2080ti.
Edit: May have been a little prone to exaggeration. Flew next to a friendly bomber, and it changed from a ‘dot’ to a big looking aircraft and back to a ‘dot’ again at 500 metres. It’s still not right though.
Have you submitted this issue to WarThunder Dev? As they are likely not rendering Hi Res & why planes don’t render until closer.
Ok. No I haven’t. Thanks for that.
There may be some sort of in-game model rendering limit or quality setting. I don’t have the game, so I cannot be specific. In Elite Dangerous, it’s called “Model Draw Distance”. You need to increase the distance/quality of the models.
Now I think I remember, @SweViver might have said something about this in his videos.
