Hi, how can you set the VRtoolkit settings?
I have no control of the SteamVR dash with a controller, don’t own a VR controller and as we know the HMD (5K+) has no button.
Is there another way to use this dash?
You can use the Pimax Experience for that as it uses the mouse for config when no controller is detected.
There is a desktop SteamVR window where you can adjust some settings. In SteamVR Home/Dashboard a game pad works as well.
As PimaxUSA said Pimax Experience can work though this might break in future as SweViver said this Project is on hold for evaluation.
Press CTRL+ Home to bring up the settings (it will show up on the mirror view on your monitor), uncheck “Performance Mode,” then use mouse/keyboard to input new values, recheck Performance Mode, then CTRL+Home to get rid of the window.
Gamepad does not work in dash though, seems to be an ancient problem…
The SteamVR Dashboard? Of so It does work as I use it. Select or start summons tge Dashboard. Press and hold
Interesting…
What gamepad are you using?
I found lots of posts where the gamepad works in everything BUT the dash.
I thought my generic xbox360 controller might be the problem, so got an official Xbox1 controller…
We’ve talked about this before…
Doesn’t work for me, using a SteamVR Controller, but it’s abandonware of course…
Xbox 1 controller. Steam does not show accurate. It is select or start holding to summ9n dashboard and iirc A & B
I still haven’t revisited my Steamcontrollers but even the standard xb1 and similar are not setup according to what Steamvr home environment claims. So likely requires a deeper dive to setup as Valve really sucks with how they changed tye input structure for non vrcontrollers.
