VR Compare comparison website
Hey I found out about this site, and it seems to be getting quite popular. It has all the info on all hmds ever made
I wonder if @risa2000 might be able to contribute to.
The site creator’s email address is there
contact@vr-compare.com
It seems to be missing a few Pimax variants
It seems that the “technical specs” related to the field of view, and pixels per degree, were most of the time taken from the marketing info, or calculated by using a wrong formula and are not correct. I could only verify few, but I would approach the rest with the same caution.
Apart from that I guess it is not a bad idea to keep a reference to all headsets.
Yes that’s why I thought of you when I heard about the website. They could use a collaborator :slight_smile:
accuracy is important.
I like the ui though , being able to compare the headsets side by side is a nice touch
Well, hmdgdb is public (HMD Geometry Database | Collected geometry data from some commercially available VR headsets.). They may use it as long as they comply with the license (Creative Commons — Attribution-ShareAlike 4.0 International — CC BY-SA 4.0).
hmdq tools (GitHub - risa2000/hmdq: HMDQ Tools - the tools for VR headsets and other hardware introspection) are also public, so they could use them as well, if they want.
