I don’t get Viveport on the Pimax 5k BE. Viveport VR not startet on the HMD.
Is there a manual for this or does someone have a tip?
Maybe try the “Compatible with Vive only games”?
EDIT: Explanation: This makes the Pimax headset identify as “Vive MV” (same as what the og Vive does) in SteamVR and hence the application.
I thought it would work without Steam VR. Just like with Oculus games. Vive Port VR runs with Steam VR.
Did you get this working? I have a 5k+ and use viveport all the time.
Yes viveport uses steamVR.
