Vive wand controller hands spazzing
Using my pimax 5k+ on pitool beta .144
SteamVR beta 1.7.15 (even none beta is the same version)
what i am seeing: Screen capture - cdee2dd95075b9ce3bc3d73df4a42991 - Gyazo
Seems one of my hand thinks it’s the other controller.
tried turning off the one that is doing it, and turn it back on.
same thing.
i can use my left hand touch pad and the right hand responds.
this seems to happen in Thelab and Space pirate trainer so far.
tried Restarting PC.
just got these controllers today.
Everything seems to be fine, but this one weird issue, where the hands are switching back and fourth like it can’t decide what hand it wants to be.
Any suggestions?
Thanks
Search here for another thread where I mentioned The Lab glitching. A suggestion to fix this was offered there and maybe it could help you as well.
Will Try the .json file.
But this is also happening in Space pirate trainer, but with both hands. :confused:
Also update to newest pitool.
That caused issues in games before, where my controllers would not show up in Vivecraft.
And caused some stuttering more as well.
.180 was not as stable as .144 is.
Why i’ve been waiting on the new beta for over a month now. :thinking:
Just downloaded the Natural locomotion demo. No Wand issues here on Pitool 180
Oh, forgot to mentioned.
This was when i was using nolo controllers when this happened.
But the stuttering was still there compared to .144.
(like it wanted to make an after image in the screen).
But it never used my GPU to it’s full potential, and still stuttered compared to the last beta.
So i went back.
(i have a liquid cooled 2080 OC)
Perhaps the title of the thread is misleading then as it refers to Vive wands.
In any case Wands are working as always for me. Just fine, at least as far as touchpads can be considered fine. :grin:
Nope, As i am now using Vive wands with my pimax and not the nolo anymore.
and it’s happening to Thelab and Space pirate trainer where the hands are flickering back and fourth.
Like it can’t decide what hand it wants to be.
Not sure if it’s something with the steamvr 1.7.15 that is out now or not.
but, someone pointed it out that thelab .json file had some issues.
i have not tested it out after applying the fix yet.
I just installed The Lab and the wands are truly pooched as you describe. GL with the fix. As for BS, I don’t have it but, I’d guess Valve and SteamVR are likely the culprits while fleshing out controllers like Index.
When using Index Controllers with the Pimax 5K+ in several games such as Contractors VR and The Talos Principle VR the fingers are constantly twitching. Do more people have this problem?
I’m seeing a problem with left wand controller in onward/pavlov. It doesn’t happen very often one every 3-60 seconds. I’ll test The Lab, Space Pirate Trainer, Contractors later today.
[UPDATE] didnt see any problems in those games
