I’m really struggling to remove the MAS from it’s hinges. How exactly did you guys do it? I’ve tried pushing it in and then out but it stays on pretty well.
Edit: Just realized it’s easy once I removed the face gasket.
God dammit, I accidentally broke the eye tracking compatible top adapter because I wasn’t careful enough with it. I’ll have to get it reprinted
I can’t get the DAS Side adapters to attach to the DAS! It’s like it doesn’t fit or something. I’m using this one: Pimax DAS Adapter - Google Drive
Pimax DAS adapter side
Update: I had to press it really hard into a table to get it to hook
Yeah, the Vive das clamps are much tighter on the 8KX, you have to be careful but they’ll go on. Removal does require taking the rubber/foam insert out.
I think I just ran mine straight though. I’ll have to check later tonight.
