I’m new to VR. I’ve received my 5K+ and have bought a single VIVE base station (base station only, not headset or link box). The Pimax is recognized in steamvr and pitool, but the base station isn’t recognized by either. In steamvr settings I get a “Bluetooth services not available” messages in the Bluetooth tab. Not sure how to connect it or if I need additional hardware (HTC link box) or additional software (VIVE, etc)? Any suggestions? Thanks in advance for the help.
Does your light house have the green LED lit at the top and 9 red LED’s lit? Also maybe configure the switch in the back of the LH to a different setting
Turn off computer and turn both LH on. Then turn on your computer and open pitool. Then turn on the hmd and then turn both controller on(make sure both controllers are paired with the 5k headset).
My lighthouses wasnt tracking until i paired both of the controllers.
I had this problem when I first got my Pimax 5k plus, using a single LH setup as I only use it for sim racing. After a couple of weeks away I’ve come back to it and we’re back to the same issue. But this time it seems I can’t fix it. All drivers are up to date but PiTool keeps telling me the LH is disconnected. I seriously regret buying this headset. For what these cost, I expected things to be more ‘plug n play’ than this. Sure, I expected some hiccups or a little tinkering but I didn’t expect to have to ‘turn this on, turn this off’, ‘delete these files’, ‘turn things on in this order’ etc etc. About at my wits end here.
I have the same issues. I wanted to use it for sim racing and flying. I spent half a day tinkering with my lighthouse and 5kplus. My pumas has been collecting dust ever since. Went right back to my Oculus. Considering revisiting and have found this topic. Still looks to be no difinitive answer.
I did get mine to working. Got a refurb Vive link box and it connects every time now. When I connect I have to turn the headset around and to and from the sensor, then it starts tracking.
