Having a cold (again) and almost no voice, but hey it wont stop me from VR lol. Spent some time last night in Virtual Desktop with the 8KX, and decided to make a comparison with Valve Index. Like night and day if you ask me. 8KX is easily the king of virtual desktop work. But hey who cares about my opinion, right?
So I made some through-the-lens photos in Virtual Desktop. Dont judge me, I really did my best. Valve Index simply dont get better in TTL, believe me. The sharpness is not there on Index once you let the camera have a closer look.
Anyway, so I used one of my 1440p monitors to mirror into Virtual Desktop, put it on 7m distance, 72% curve (for no reason), and made various TTL photos with Screen Sizes 150, 130, 110, 90, 70 and 50.
Basically, for each step, the virtual desktop gets smaller.
All photos taken from exactly the same distance (fixed distance) of course, with both headsets.
Shot with GH5, 12mm (24mm full frame equivalent) so no macro here. Same settings on all photos.
You should download the images in full size!
I will leave the opinions up to you, but all I can say is that when using the 8KX, I can clearly read the text under the desktop icons down to screen size 60 or maybe 55. With screen size around 50 and lower, its just getting too shimmery.
Remember its a 1440p monitor Im mirroring in Virtual Desktop, so if you want to try on your own with any headset to get an idea, you need to use a 1440p resolution on your virtual desktop.
The focus point is the “Revive Dashboard” icon and text.
Let me know what you think!
