Pimax 5k XR
Windows 10 pro 64
GPU 2080ti,
CPU Ryzen 7 3800X
32 gig
I have tried both versions Version: v1.0.1.255 and Version: V 2020.3.24. diagnostics in both versions indicate missing VC Components. the diagnostic page has a “repair” button beside the failure but the link is broken.
It appears to link to a file called VC.Zip
anyone have this or can send me where to find it. My wife gave me this as a Birthday gift at the beginning of the week… she is sad now as I am frustrated. I submitted a ticket two days ago which seems to not be lost?.
I have checked my PiTool and it seems it uses mostly v140 runtime, which would correspond to VC 2015 redist. But I also found reference to msvcr100.dll (which may refer to VC 2010!).
Could you list all DLLs you have installed in: C:\Program Files\Pimax\Runtime?
You seem to have the same CRT DLLs as I do, despite you trying to hide them behind the bubble . At least in this directory. What I found different, you are missing jsoncpp.dll and have one I do not have libusb-1.0.dll. I am pretty sure, neither is coming from VC redist, but are open source libs. You may try to get jsoncpp.dll from some older version.
I believe there were reports that some PiTool versions were missing some components (so people who simply installed them over the older one did not notice, but I do not know which versions they were, or if it was really confirmed). I am myself on pretty old version v132.
