Valve index controllers: Can’t access the steamvr controller config profiles ಠ_ಠ
Payday 2. R I can’t even move, and I can’t access the steamvr controller profiles (only the main community hub of various profiles) so I cannot rebind anything.
@PimaxUSA
I really wanna play payday :frowning:
How is that a Pimax issue?
You can change the config directly in Steam (not SteamVR) too.
If it’s index controllers or wands could be how they plug in to one another.
@aesopfabled when in vr summon bigscreen like interface. Check setting gear on the dashboard there are some controller settings there.
When you say steam controller are you meaning steam gamepad?
The usual way is to have the game running, press the controller menu button, there’s 5 circles near the bottom, select the right hand one which is settings, then controller settings, your game should be showing on the right hand side, select that and the available binds should be there, payday 2 is a popular game so I should think there’s some shared bindings already but you can always try to make one yourself by editing the default binding, if you do create a good bind, please publish it to the workshop so others can use your creation and don’t be afraid to experiment, if you don’t like what you create then just don’t save it, the default bind is always there as backup.
