I´m unable to switch to direct mode anywhere. I have uninstalled everything and reinstalled. If I select the Piplay Icon in the botton right tray the mode detect is grey. Steam VR gives error because my goggles are stuck in extended mode.
I´m using a 970 nvidia card, driver 362.00, Win 10.
Unfortunately, it didn’t work work for me, the googles refuse to switch to Direct Mode.
I use the program but when i select OC_direct and click restart it switches to OC_extend,
and not OC_Direct. Strangely that now OC_direct is greyed out after restart.
Yes I know Pimax = Direct mode, but if you look at the screenshot and at the Pimax splash screen and the program itself, it stays in OC extended even if you select PIMAX and restart.
Maybe this is a reason of your direct mode trouble.
check for this.
Attention: If your PC has integrated graphics (desktop and laptop), maybe you can’t use the Direct mode if you haven’t close the integrated graphics at all, please try to disable the Integratedl Graphics on the Mainbooard and use the discrete graphics only.
Have the same Problem. OC_direct didn’t work.Have a gtx 1080 and Windows 10
Maybe the OCSoftware have some Tools to do that
PIMAX have it. In windows\piserver\pimax you can find it.
