Twack3rs Varjo VR-3 impressions
Based on what? I haven’t seen anything that wasn’t pure speculation. As in “The Crystal seems similar to the Aero. Therefore it must have the very same panels from the same manufacturer.”
I hope not!
iirc they have the same resolution. But the panels are not the same, surely, they have much different fov’s for a start. But is fov down to the lenses too?
The Aero is 2880x2720 and the Crystal is 2880x2880.
Aero max FPS is 90Hz. Crystal max FPS is 160Hz.
Yes. And how the panels are positioned.
thanks, interesting info.
Pimax is also using Qled.
I neither said I thought so, nor did I say the same displays…Ive just seen a couple instances where the same manufacturer was put forth as a possible supplier and just speculatively. Who knows, im not an OEM procurement expert. Like you, I just dont want dead pixels.
