I backed the Tundra Trackers on Kickstarter, and they are starting deliveries now. Tundra labs held a meetup in VRChat recently where they mentioned that some Pimax users who have gotten early access to the trackers reported that they do not work with Pitool. I had assumed that they would connect straight to SteamVR and thus bypass any problems with Pitool, but from what I heard during the meetup, that doesn’t sound like it is the case. Have we heard anything from Pimax regarding compatibility between the Pimax and Tundra trackers?
This might be a question for Tundra as well. Though Tundra uses it’s own special dongles so for a time might only be directly paired in there own ap in steam?
At the meetup, Tundra made it sound like it was an issue with Pitool and it should be brought up with Pimax. I suppose I’ll have to wait and see though. HTC trackers still pair through Pitool, right? I’d imagine that they would operate exactly like that.
Hello,
We’ve made contact with Jason from Tundra Trackers. Both teams are collaborating on compatibility.
More likely there should some progress being held atm.
