my batteri is fully charged … anny tip_+
Restart the computer,
That was the case for me too, after a reboot it worked…
restart pc , dosent work . thnx for tip
the strange thing is the battery % is not showing in software.-
is it possible to use duf? manual install the firmware like 8kx?
Connect the crystal directly to the PC without a USB hub. then reboot then it works, I mean that’s how I did it…
Stil not working, hmm
trying to swap batteries again
USB C on the side of the crystal is also connected?
that’s really weird…
ye usb-c on the side is connected
maybe full re install the software . i gonna try it
not working with re-install the software. i give up . used to much time in my life to get this pimaxian to work .
Pity…
open a ticket and please let me know if there is a solution
I have it now:
- reinstall old Play software (PimaxPlay V1.16.01 )
2.Firmware update the Crystal
3.Update PimaxPlay
Have fun
thank you…
