Hi all
i have the pimax 4k and i use it primarily in flight simulation “DCS World”
the issue is the tracking drift as most would know. if u look around 90 degrees to either side the tracking does not return to centre. i would like to know if this is a hardware limitation or if it relies on software aswell. have pimax just disregarded the issue because they are focused on the 8K ? i personally am happy with basic 4k due to pc requirements to run vr in general.
since i fly DCS 95% of the time i use the headset is there an older version of piplay that worked better, i have read that DCS has native VR support for the oculus and u dont need to use steam VR. is this possible with the pimax ? as i dont have DCS installed in steam but it requires steam to run as well as pi play and oculus home. so i have many programs openning on a lower end system.
