Friendly reminder: Iโm stoked to try this mode out with pavlov and vorpx. And also remind you guys that I will spend eternity begging for full fov 120 fps mode and that the DP cable can handle the throughput bandwidth for it
You haxor!
2ฬฬคฬฏฬฬอฬกฬด0ออฬอฬฏฬทอข อฬฝฬออฬอฬฬอฬจcฬออชฬฬฒhฬฬ อคฬฬฑฬตaฬอฬฬฒอขrอคฬณฬฌฬฉฬฎฬอออaอญอฬฟฬcอฏอฃอฬฬฬฎอฬฬอฬอtอฉอฎออฬฬฬฒeฬฬฬฬอฬนอฬออ ฬดrอชฬอฬญsฬฝอออฬออฬฏอฬ อคฬอฃอฏฬผฬฬฐฬบฬ
Maybe the analogix chip canโt though :^)
Just wait for Brainwarp 2.0 in 2077 :^)
Itโs in China right now where everyone is on Holiday.
โฆtill the next Holiday
The thirst is realโฆ
that title font is horrendous, feels like Iโm looking at 5K+ large FOV distortion /s
Yeah looks like those slave like working conditions in China are too much /S
Always on holiday.
I believe it will be called Cyberpunk by then .
Hopefully really soon for pitool.
Hope for soonish.
I hope the GPU utilisation twitching on 180 will get fixed as well
They should just go ahead and release the update. Itโs so hard to wait.
Unfortunately, nothing will be released this week. Itโs a national holiday (all week) in China.
gib me update now pls
I will push the devs to release it asap All I can say is that it works just as promised, after giving it some time in Florida. Lets hope they can add this for Normal FOV as well soon!
@SweViver Considering push to open source, can you comment does this 120hz mode mean Smart boost is in use? Aka 60hz per eye + smart smoothing to 120? I think that Smart Boost is limited to small fov because periphery(monoscopic part) would be seen in 60hz and cause discomfort.
Yeah! 120fps in 150ยฐ FOV should be awesome.
Though it would help if I could actually set the fov to normal, my hmd seems to be stuck on largeโฆ
If you could push them to release the PiTool beta code base on github as well that would be great, the current version they provided is pretty useless without all the other functionality and fixes they added in the beta.
Yeh hurry up with the 120hz update Iโm getting sick of the oculus quest lagging andtracking like trash nowadays
Iโve been dying to try the new update. Just testing it would be okay too for me.
