The new piplay does not work with DCS. In the v.1.1.92 you could set it to 2k support (2560 x 1440) in the device setting and the menu was operational. but now the menu is completely gone. A small fix soon?
jtkfox is your problem similar or same as this one?
Yes with piplay V.1.2.33 and in 1.1.92 if you don’t set the piplay to 2k support in the device settings. It get just little better when you set it to 2k support, you get the first letter on the menu line hehehe so you have to remember what is what.
