Which I do not… But, if you have both headsets, would you please give a brief post comparing the major discussed points? So, without going into a full review would you simply compare the colour, blacks, SDE, and which HMD you use more, day to day. I totally appreciate that it’s subjective, but, at the end of the day - Which headset are backers with both actually using, more?
Much of the 5k+ Vs 8k threads deal in theory and technical issues, I’m hoping to simplify it a little by just dealing with the end results of actual 8k/5k+ usage… and how the major points of discussion are affecting real users.
Thanks if you can help!
