Hi everyone,
this guide is fully based on Fresco’s post, showing that the HTC DAS speakers can in fact be added to the SMAM. After finding the default SMAS speakers underwhelming, I decide to try to mod my SMAS, following his footsteps. Since a lot of people were asking for pictures, I documented the process and now sharing the results.
Removing the SMAS speaker is very easy: you need to peel off the foam padding on the sides, and this will reveal a single screw holding the speakers in place:
I have to give it to Pimax, these really are modular: all you need to do after unscrewing that single screw is pull the speakers out:
They pop out very easily:
Be careful not to lose the original screws - my solution was to screw them right back in to the speakers which went back to the 8K-X box:
Next up: removing the DAS speakers. This also starts with removing the foam padding:
Again, you need to remove one screw to free the speakers (leave the side screws alone):
They come out easily - hold on to the screw, it will be important!
Next, we pull out the cabling, including the little T-junction (I used a small screwdriver to pop these out):
Out you go:
Other side, same deal:
Notice how the screw sizes differ between HTC and Pimax:
So now we have the whole DAS assembly out:
13: This is where it gets complicated. The central core of the HTC solution relies on this metal thingie to go into a crevice on the speakers, which the Pimax solution completely lacks.
14: You can proceed and simply screw it on with the original HTC screw, but the result will be quite wobbly - the speaker will only be held in place by this central core and lacks proper support. Also, this damn little thing can move in and out on its own, so on top of sideways wobbliness, you get later movement also:
The solution (also mentioned by Fresco) is to put some washers around the metal thingie. How big? You need 10mm of thickness:
… and 22-23mm diameter. The core is rougly 6mm in diameter:
I first tried these:
Looks like a great fit, doesn’t it?
19: They also stack up nicely but go over the central rise and don’t eliminate the wobbliness. Not to mention the little plastic pin which is responsible for the swivel range on the original DAS design (completely useless here):
- As a normal human being, I should have gone to a hardware store to find bigger washers… but as a family man, tinkering time is when everyone’s asleep and shops are closed, so I’ve decided to create my own custom risers from this hard rubber that I had lying around from a previous project (anti-swivel mechanism for swivel chair pedal action… don’t ask):
21: I cut it up into nice 25x25mm squares:
22: Then came the custom made butchering. It would have made great entertainment (for you) to record this process but holding a smartphone while attacking thick rubber with an Exacto knife is recipe for an accident so I decided not to. The result was this:
- Neat, huh?
24: Only took me about an hour to carve them all up. Luckily, for the second and third layer I only needed a hole in the middle:
25: Now the real fun began: trying to hit the metal thingie with the small screw and remember - the metal thingie can be pushed inside very easily. The process was not unlike trying to dock a steam locomotive to the International Space Station, but I eventually succeeded:
- Now repeat for the other side, and we’re almost done! Few cosmetic tweaks to secure the cables:
27: Had to unplug the original cables and plug the DAS cable in on the left side only:
28: Right side was much cleaner, no twisty cable:
29: I simply twisted the original plugs around the swivel know until I can think of something cleaner:
30: The cable connecting the two speakers go under the back foam:
- And so after a mere 4 hours of painstaking work, I now have a fully functioning Pimax 8K-X with Vive DAS headphone:
Couple of things:
- The speaker work great, as anyone with DAS experience will tell you, it’s a night and day difference
- I no longer have volume issues, the DAS are loud enough so I could finally turn it down to about 50% (I’m on the latest 2004 version of Win 10)
- The swivel mechanism kinda works… it’s stiff but you can rotate the speakers back and forth
- I do NOT recommend making your own “washers” unless you enjoy hours of meticulous work and take pleasure in ugly solutions
Summary:
- The DAS replacement is relatively simple process, no advanced mechanical or electric skills are needed. The only catch is creating some sort of spacers to prevent the speakers from wiggling around (due to the differences in the mounting solution HTC and Pimax respectively chose).
- The audio upgrade is HUGE. I finally have my aural immersion back.
Enjoy!
PS: It’s f*cking 3am here so I won’t reply to questions for the next 5 hours minimum.
