Hello everyone
I am still looking for a solution for on the 8kx ?
I have done several tests
usb
display port
pitool
baclight 0
resolution -
but nothing fixes the problem
a little help
Hello everyone
usb
display port
pitool
baclight 0
resolution -
a little help
The upscale Blackout issues is still being evaluated as far as I know. There also having issues on the native 90hz node as well on Nvidia.
Not sure if @MikeJeffries has used the upscale mode or not but has been testing to collect data on 90hz native.
There is an option to activate pitool logging before running a game.
I have the blackout issue on native mode. I dont use upscale mode because of the blurriness compared to native. It’s happened on 75 and 90hz so far… Its been very random but i am still testing…
I never thought of this but I always lock my SteamVRSettings file with gpuSpeed values of 5000 (for the nvidia 3090) and render scale at 1.5 and i lock the file to read only so nothing can be changed unless i uncheck read only for that file. Im wondering if maybe those values affect anything?
I did a lot of testing around upscale 144
but each time and it varies in duration
the right eye goes out.
I restart the 8kx and it works again (without stopping steam and pitool).
Very strange as random bug
Ok, i bumped into something, and it may be of importance
I was experiencing random black outs in native mode, 75hz or 90hz
I fixed it at the GPU connection: somehow, the 8kx video cable was looping around my monitor video cable.
I untangled them, and made sure they were as spread apart as possible on the back of the gpu, using the 2 furthest connectors on the gpu:
No black outs ever since in 75hz, haven’t tried 90 hertz
Well I figure pimax has been having some issues figuring out the upscale mode as they ran a poll to see if people would be okay with it being removed temporarily?
yes I followed the vote
but 114 htz is still a good thing (when it works) for fast games like simulations
Agreed I believe the upscaled feature is a must as it was a key feature advertised and as you said fast moving games benefit from it.
