I set IPD to 64, sometimes try to change value to see if it is “better”.
Currently no eyestrain but I did not played long hours !
I do not have controllers and lighthouses.
I spend lots of time to test several values with pitools and steam to have correct FPS.
I used Revive and most Oculus games crashed before I remove it.
Hello, room setup did the trick, thanks !
I was able to play lots of games, DCS is amazing !
I did not spent lots of time on ED now, was excited to check if other applications were ok
I have my 5K+ for a while now too and I am also incredibly happy with it. Remeber: Usually people only come to forums if something is not working. The rest is playing VR games.
