Thundra Labs has released a new, miniature TL448K6D-VR System in Package for SteamVR Tracking.
https://tundra-labs.com/shop/tl448k6d-vr
Great that we finally have small tracking modules.
Unfortunately, they are $48.99, and it is not immediately clear how many of the GPIOs can be used for buttons.
This seems more useful.
It looks like with sensors included the price is about $130.
After reviewing the documentation, I think there are 19 GPIOs available (14 for FPGA and 5 for MCU) that can be used to operate the buttons or for other purpose.
For a hobbyist, in fact, HiveTracker can be an interesting solution. However, I do not know if it is available in mass production.
For a mass-producing company, TL448K6D-VR seems like a better solution. Especially that when you buy a larger amount, you can get a lower price.
The way the electronics manufacturing industry works, anything for which PCB layouts and Bill-Of-Materials files exist, is ‘available in mass production’. Send your files to a company like PCBWay, and you can have quantities from something like 3 to 3 million made for a fee less than the cost of what was put on the board.
Open source, and cheap enough to use a separate module for each position tracked, is more appealing to me, than a device best suited to make more brick sized trackers.
This is why I wish the Oculus Constellation system had more traction.
- An LED sending out a 10-bit coded sequence takes next to nothing in power consumption.
- Camera optics can be cheaply completely characterized and scaled up to any degree of both accuracy and precision (lighthouses simply cannot)
- Straightforward computer processing can eliminate almost any ‘multipath’ issues.
- No separate calibration tracker required - floor and room objects remain exactly calibrated relative to the cameras.
- As many cameras as desired to cover arbitrarily large areas.
- Possibility to flip the same system around and more or less get built-in support for both inside-out and outside-in tracking, which would be great for demos.
- Transmit power control can achieve sub-pixel accuracy and prevent the sensors from being blinded when too close.
- A separate, dedicate computer, or GPGPU, can be used as a coprocessor, making the computing load a non-issue.
