I received an email stating the survey closed on the 30th November. I hadn’t got round to completing it by the specified date as I have been moving house, busy with work etc. I have since completed it and it has been submitted. Are there any notable ramifications of having submitted it after the deadline?
Not sure @aesopfabled i think has backed other projects.
@Matthew.Xu might be away but even @deletedpimaxrep1 or @Pimax-Support can likely be of assistance. You may need ti give them details of your order directly.
Thank you for your response, I shall attempt to contact the people you mentioned. This has helped to quell my anxieties somewhat.
The survey itself should be no problem, it will be submitted like normal to Kickstarter.
But they probably need to do a new export for the new info if they already did it.
So yeah @Co7in, sending a message to the relevant Pimax people is the proper way to go. My contact so far with them has always led to them sorting everything out.
Thank you for your assistance, I have contacted Pimax Support. Hopefully they will be able to amend the export without it having caused much hassle.
Hi, please be assured that we have already received your survey : )
Thank you for this confirmation. It is a huge relief to hear that. Many apologies for my tardiness.
Is there a place where I can see my response to the survey?
Log in to Kickstarter.
Click on your avatar in the top right corner.
Select “Backed projects”.
Click on the Pimax entry in the list.
In the centre of the window that opens there are three tabs, “Reward”, “Survey” and “Messages”.
Click on “Survey” and it should show your responses to the questionnaire.
