Hello there.
I was wondering if the programmers for Piplay can add something to the next version of Piplay…
The ability to resize the Piplay window. I use triple monitors (sim racing rig) and use a windows desktop resolution of 5760 X 1080, the Piplay software doesn’t scale very well for this kind of windows desktop, it spans all three monitors with some of the text being squished (SteamVR and Recenter options). Being able to resize the Piplay window would solve this problem.
Thank you for your time.
Regards: Jack
Hi Jack, well noted with thanks. I have reported your kind suggestion to our engineers, we will see.
