Stuck in "Searching for Device" "Device Disconnected" loop
Device is stuck eternally going between “Searching for Device” and then “Device Disconnected”.
Changing it to Video mode works, but Pimax mode doesn’t.
The previous drivers worked okay-ish, or at least booted properly, but some Steam games didn’t detect the headset.
I have the drivers from PiSetup_1.2.74. I’m using a Geforce 1070. I’ve tried both with latest drivers (382.33) and some older ones (381.89) as per a recommendation from another thread here. Neither works though.
I’ve tried contacting Pimax support over Skype, but I’m not getting any response, not even an automated one.
Okay
@PIMAX-Support
Use the @name to draw attention.
Check this link as well
http://community.openmr.ai/t/piplay-installation-and-using-instructions/130?u=heliosurge
Try this:
http://community.openmr.ai/t/piplay-beta-version-1-2-74-is-available-for-downloading/2088/28?u=sjefdeklerk
