Hi I got the Pimax BE and I struggle to find the best software for it as the newest seemed to have the best performance but I can’t disable the gyro to use opentrack as it still has a terrible drift with the gyros
Welcome back!
Pitool should work. Not sure if turn off gyro’s work as an option.
@Enopho likely can tell you which version of pitool currently works well.
I currently use Pitool 1.0.1.132 with firmware 1.0.0.265
Regards
Mike
Thank you both. And disabling the gyro doesn’t help as the boxes in iRacing are moving with my head motion. So I‘ll have to stick with the gyros or is there any other option for head motion?
