I am still trying to get 90 hz from my PC,it is the latest with a 3090 graphics
card etc.Everything works perfectly using V1.01.271 and V2.1.255.256 but as
soon as I upgrade to M298 Engineer test it comes up with 10500 fault and
“Disconnected”
This seems crazy as many people are having no problem with the upgrade
would it be possible for you to check my machine for me ??
I have tried everything I can think of.
Thanks
skellum
G’day Neil,
Tried that awhile ago,no luck at this stage I must have tried everything which has
been written in this forum.
Thanks anyway for your help
skellum
G’Day Brogs.
If you put in a support claim ,ask Adonis to send the ammended files,he will
also send the various Irl’s to explain the sequence to flash your dfu.
All the best
skellum
There were some bumps though. After flashing got the dreaded green…blue …red blinking light. I looked up fix for that. Some dfu file in device manager conflict. Had to restart computer few times.
As most here know I’m avid iracer. Since I updated firmware I haven’t been able to race. I try to even to test track but iracing doesn’t load…just stuck in buffer. Weird
